z32 wants to die when in neutral
Trevor-z32
Car: 1995 300zx, N/A, Slick top
Hey guys, i got a 95 z32, and when im coasting in neutral and start braking, it boggs down to around 500 rpms, and some times dies completely. It's throwing the egr code too, idk if that would have anything to do with it? Anyone have any idea?
Slizz
Car: 92 nissan 300zx
Could be a vacuum leak? Get some starting fluid or water and spray it around spots on your engine and if it changes idle in 1 spot continuously or even bogs down and dies, something in that area could be leaking! Good luck! Mine was doing the same thing, but i havent driven it in awhile so I dont know if I fixed it, Could also try pulling the iaac assembly off and cleaning it out, or spraying carb cleaner through the hose that goes to it?
Trevor-z32
I'll give it a shot. Thanks!
Slizz
Yep no problem! Good luck!
