spooled240 wrote:hey I wanted to double check with the s14 gurus on this forum: i'm planning on getting a z32 vlsd with abs (i hear the abs option does not matter) with 94-96 j30 axles for a 97 s14 without abs. This is all I need correct? I can still use the z32 half shafts from the diff right? I did a lot of searching but still wanted to check w/ this forum before I spend the big bux. -josh
To overcome the extra length at the nose of the diff you can:
1) Install it and see if your driveshaft and transmission mounts have enough play to soak up the extra length.
2) Get a driveshaft from an ABS equipped 240SX...it's .75" inch shorter.
