Z32 upgrade 5 lug hub question.
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Ok so after quick searching I couldn't find the answer to my question.
I finally got off my lazy arse and ordered some Z32 Brembos so I can finally do my upgrade (Z32 30MM Alum w/stainless conversion lines). I don't plan on mangeling the stock rotor dust shields to fit the new brakes so instead I am just going to remove them.
My question is.... what size cotter pins do I need to re-install the front hubs once I remove them to take the shields out? Also, how do I get those hub dust caps off to get to the nut? I tried to take them off a few years ago but couldn't budge them.
Thanks guys!
-Jason
Fenvy
Car: 2005 350Z Base 6MT
for the hub nut cap, I use the flat head and a mallet
for the shield, isn't it behind the hub? once the hub comes off the shield comes right off
nismofly
Car: 89 Nissan 240SX Hatch
just cut the shields, since you dont need to change the hubs its not worth all the effort just to get the shields off
and btw z32's arent brembos
ddgsxr504
nismofly wrote:just cut the shields, since you dont need to change the hubs its not worth all the effort just to get the shields off
Sorry I meant Brembo rotors.. I already have the other stuff.
The reason I didn't want to cut them is because they look all mangled. I guess if I used a pneumatic cutting wheel I could make it look decent but that adds more work anyway.
Fenvy
I would remove them but cutting works too if you have the right tool.
good luck
ddgsxr504
So does anyone know what size I need?
naed240sx
Car: .....
Just buy a cotter pin assortment from autozone. It's a good thing to have around anyways.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
I just ordered some cotter pins from Courtesy Nissan for this upgrade.Front axle:00921-4302ARear axle:00921-5402ARLCA, FLCA, front outer tie rods:08921-3202A
Modified by positronone at 6:35 PM 8/31/2007
