Also another good thing to try is to check your compression.
Also i have a question you say would a boost leak cause your plugs to foul...
Does this mean your plugs do foul everynow and then??? If so do they smell like oil or gas or a little mixture of both?? Also does your oil smell like gas??
Also have you ever seen your car stop reving meaning it will rev up to like 3k then act like thats the rev limit??
My car's plugs smell like a mix of the 2 and the oil smells like straight up gas... Which is why im doing a rebuild... My car's current (original motor has 108k miles) and 125 psi in all 6 cylinders
But its all good cause i have a healthy power plant in the works
Also OMG im almost at 1000 posts hahah
