I just performed an injector test with my new Inova multimeter:
Set the Ohm to 20 on the meter:
i tested 3 injectors and they all started climbing up to 18... and stopped!!
did i do this correctly? i followed the steps on the z32 wiki link, i have not checked the other 3 injectors as they are harder to access. However the car does run normal, i do smell fuel when its at cold start, and at idle it does have a faint sputter, but clears up once the RPM's go up/ and im only boosting (according to the stock boost meter) about 6 psi??
from what i understand and have known throughout the years, the TT's boost is @ 9.5 which on the needle is a bit passed the half way mark, my car does not ever reach that mark. i have replaced a few brittle vacuum lines and celaned up the MAF and TB's, and changed the spark plugs.
Now back to the injectors, what you guys think? i also ran a diagnosis from the ECU and it was 5-5 which is no problems.
please advise.
AC
