Z32 TT guys... Need suggestions as to why running safety boost levels...
S13CoupeLuvr
Car: '93 240sx SR20 dark green hatch
'95 Maxima white 5spd
Hey everybody. I've got a friend here in St. Louis with a '91 maroon TT and he just had the JWT ECU upgrade installed and the JWT Pop-charger to go along with it, but the engine is running on safety-boost levels (claimed 7psi). Anyone have any suggestions I can give this guy? VGs are too complicated for my tastes... He has original O2 sensors in the car (71,xxx miles on the car), and I made an uneducated guess that these may be problematic. I also already suggested that he reset the ECU, for the Pop-charger may have been installed after the ECU was. More suggestions?
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
go to http://www.twinturbo.net/
Look in the tech section.
Mine was running safety boost because of faulty knock sensor.Look up the secrtion on ecu diagnostics. Should give you a code 34 for knock sensor.
KaZ (VaBch)
Knock sensor was going to be my first suggestion... did you guys install Boost Jets as you were instructed w/ the ECU? You won't run any higher boost without the boost jets. ECU just adjusts the fuel maps and retards the timing a little for the higher boost levels.
