Ace2cool »
https://forums.nicoclub.com/ace2cool-u95120.html
Sun Jan 18, 2015 5:06 pm
Wait, never mind, I haven't bled a Z in so long I forgot there isn't one on the master.
One thing to make sure is that you are keeping the fluid level high while bleeding. As few as 3 pump cycles can get the fluid level low enough to suck air, and when you go to fill it, you won't even know air got sucked in, because the level is still far above the suction point.
Also, those speed bleeders can cause more problems than they solve. I'd get a friend and do it the old fashioned way.
