evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Jun 08, 2010 1:38 pm
I believe the dual friction is a stage3, does it have a sprung hub? I had the stage 4 ro 5, it was a 6 puck solid hub
yes heavy clutch pp's can shorten the life of a thrust bearing but anything with a sprung hub shouldn't be enough extra wear to matter
and while not propper break in can shoorten the life of the clutch, it shouldn't shorten it that much unless it's not adjusted properly, multiplate diske tend to be thicker requiring the to bearing to be adjusted hopefully you can get enough adjustment at the pedal
here's the think, race cars, don't get driven ont he street and get little to no break in, they often use multiplate clutches, thsi lack fo break in will shorten the life of the clutch but adjusted propperly it will bed in quickly and work just fine, stop by the pits at any drag race ro roar race and you'll see brand new clutches get broke in on the track
