Link would have been good. http://www.ipgparts.com/produc...t.htmaustins240 wrote:check out mazworks, you will need their kit to fit the trans to a KA/SR. comes with a driveshaft too.
they are different and need to be changed. the length is different, i'd reccomend a driveshaft shop do the "surgery" to get the length, balance and connections right.Boda wrote:
So does the SR prop shaft fit or do I need a z32 prop shaft and weld it to the SR.
The price is also at least the double then a used and checked over z32 transmission. We have s14 model here around 600bhp who drives with z32 transmission and they still worksDrifterProdigy85 wrote:Z32 transmission is strong but dont buy into the misconception that its indestructable. Mazworx uses it in there IHRA Drag Car but they also have a PPG Dog Gear Set installed for added strength and clutchless shifts. I think OS Giken Gear Set for the SR is probably just as good as the stock Z32 Trans but its just my opinion.
