Z32 Transmission in J30?
Midwest_Drift_Shop
Car: 85 300ZX Slicktop, 85 Maxima Wagon Turbo, 87 200SX, 93 Infiniti J30, 01 Pathfinder 3.5L
Hello, Im new to NICO. I've got a question about my J30.
So one day I was on my way to college. I got out on to my highway, hit the gas, the car accelerated to about 30, then the revs went up, and I lost all power to the ground. My transmission is totaly dead.
I know that the RE4R01A is used in the J, and the N/A Z32. Will the RE4R03A in the TT Z32 work in the J?
Whats the difference in the RE4R01A and the RE4R03A? I know that the RE4R03A is more beefy to handle the extra HP from the VG30DETT, but are they different in physical size?
On ebay, I seem to find alot more RE4R03A's than RE4R01A's, and they seem to be about the same price.
95-J30tt
Car: 95 Infiniti J30tt (Twin Turbo)
there are differences, the output shaft is larger (where the transmission connects to the drive-shaf), you will also need to get a TT flywheel to fit the larger torque converter (the flywheel is a direct bolt on), and little wiring issues, other than that, it should bolt in, however, i would suggest that you stick with the stock transmission, hope this helps, good luck
naladude911
Car: 2001 Infiniti QX4
I read somewhere that the QX4/PAthfinder uses the same transmission
