Hello everyone,
Unable to start engine after installing SZ cam 24+1 trigger kit on a VG30DETT with a Link G4X pnp ECU.
Trigger offset 169 deg; base timing 15 BTDC.
Set the gap to half turn for the sensor; I've checked my signal wiring for terminals 41-51 and 42-52.
Old trigger: stock CAS with AEM trigger wheel the offset was 269.
Maybe I lost those 100 degrees because I installed the wheel incorrectly (instructions state the hole in the rotor and the exhaust pulley must line up); settings are incorrect?
Any ideas?
