forgot to check that!
Anyways I tried to troubleshoot today; started it up. Car runs fine... I notice a slightly higher idle and the fan is constantly on. Even though the car isn't warmed up yet!
So I take it for a ride to see if the stumbling issue comes back.
A couple of km's down the road it's warmed up and i can provoke a slight stumble and the hesitation gets bigger. It feels powerless, on the way back I try a full throttle pull, it's gutless and hesitates. No power at all, feels like a boost leak or maybe even like a broken maf!
So I come infront of the garage and the car just dies, I start it up again and it idles like crap, hunting, and I notice the boostmeter in the dash is a little higher than it should be when idling.
I floor it, rpms stop at 2-2500 maybe 3000 and then it dies, or if I let go of the throttle it returns to crappy idle. But I can slowly and gently raise the revs to max... sounds like a broken maf. But no fault codes, only 13 and 21; water temp circuit and ignition signal circuit.
I did these tests:
http://www.300zx-twinturbo.com/cgi-bin/ ... &total=190
Except for C('cause I don't have a logic probe), but I tried to connect a test light and it lit up and blinked sort of, so I guess signal is good :/
I also tried the ptu check, page 179 in the EF&EC section,
http://www.300zx-twinturbo.com/cgi-bin/ ... &total=190 there wasn't any continuity anywhere there should....
