Let me get this right.The rear strut and springs on the Q45 are the same as the Z32 but the Z32 are wider?thejapino wrote:Yes, still running FRONT Z32 shocks + brackets in the rear of my Q. And they're still shorter than rear Q shocks by almost 2".
They are very similar, not the same. I didn't say anything about springs b/c they are different: length, coil ID. Didn't i tell you this already?? This info is in numerous threads including the two that Yellow S13 posted in his first post. READ, COMPREHENDunknown007 wrote:
Im gonna toss on some rear Z32 suspension in the rear of the Q and if it's the same thing then I'm gonna have to save another to buy fronts.Let me know.Thanks.
I reread this at home and understood what you said.I just got lazy and forgot to edit my post my bad.I thought it said springs but I read it wrong.Thanks and no you haven't told me about the shocks being same when compressed.Well I'm far from starting it's been raining a lot.Thanks.thejapino wrote:
I would say using a shock and spring combination for a car that is hundreds of pounds lighter is a pretty ignorant solution, but evidently accepatable by some Very Impaired Performance types.Rex wrote:And non-OEM does not equate to VIP, comments made drawing a direct connection between the two, only shows ignorance.
Sorry, didn't realize you were running a Z32 suspension. Who else is?Maybe you can report on your findings/success.unknown007 wrote:This guy is doing something that a lot of us have done
Sorry if you have typed it as like I've done it but I haven't.I'm still waiting to get the car running first but don't worry sure will let you know.We're not the only ones who will or are running it. Let's all get along.Trumpkin wrote:
Agreed!unknown007 wrote: Let's all get along.
