rogoman »
https://forums.nicoclub.com/rogoman-u37451.html
Fri Dec 29, 2006 6:34 am
The Z32 uses the 2 bolt rear cover so if you own an S13 you'll need to switch it. The biggest problem with the Z32 is that the output flanges are different. They look like a '5 star' flange where the 240SX uses 3 sets of 2.
You will also need 2 longer mounting bolts for the S13 chassis, and 2 large washers for the front mounts...to be used with the large bushings on the front mounts.
Listed here are some R200V VLSDs that will also work:
Infiniti J30 95+ , No mods needed, but might need driveshaft that's used because of ABS sensor Infiniti J30 pre 95 , Needs new output flanges Infiniti M30 , No mods Infiniti Q45 , No mods
