So I know that in order to intall Z32 rear calipers on an S14 you need the Z32 uprights and R33 e-brake cables to run the drum set-up.
My question is... will just the Z32 rear calipers bolt on to the stock S14 knuckles. The reason I ask is because I plan on running a hydraulic ebrake set-up that will "T" in with the brake lines on the caliper so the drums and cables won't be necessary.
Thanks guys.
-Jason
