Z32 Rear Brake Swap: Anchor Bolt Question
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
Hey guys,
I have one quick question for you guys. I've been searching all over NICO and Google, but can't seem to find the right answer. I've found a crap load of links, but I'm still confused as hell. If I use the N/A Z32 hubs along with the Z32 backing plates, but the 240SX kunckles, what kind of anchor bolt am I supposed to use? Will it matter since I'm going to use the Z32 hubs?
Thanks in advance.
94_240sx
Car: 94_240SX
It depends. What kind of hub are you going to use? One with the lip or without the lip? With lip, you need thin anchor bolt and thick one without the lip. Hubs vary by the year, not buy the model(TT/NA). I kept s13 4-lug hub, so I used thick anchor bolts. I know it because my z32 rear brake parts came with hub with the lip, so I had to source thick anchor bolts and it wasn't easy since Nissan discontinued it.
This is the thread you need.zer...age=3
Thin anchor bolt and hub w/lip combination.
