z32 rear brake on s13
aucerumo
Car: 07 Versa and 1985 Ae86
hi i have z32 rear brake calipers, rotors,and ebrake that come wiht dust cover shield. would they fit on my s13 if i use the old 4 lugs hub and redrill the z32 rotor.
jr_ss
Car: 95' S14
Everything you need to know is here http://importnut.net/300zxbrakeswap.htm.
And one other thing, learn how to use the search button . This topic has been covered thousands of times...
hannibal
Car: Red Line to Glenmont
The easiest way is to use the entire Z32 rear spindle if you got it. It uses a different rear shock mount though.
Welcome to NICO by the way...
crzycav86
Car: 93 Nissan 240SX KAT
yes. you can do it as you said.
you have to take apart the ebrake assembly to separate it from the upright and hub, though... which is easy as long as you dont lose the parts. but yeah, it all bolts up perfectly.
