Z32 Power steering pump failure, replaced, still no steering
Dazmcp
Car: 91 300zx Twin turbo j spec
Hi
Was driving the other day when the power steering pump failed, the pully and shaft came right through the front of the pump and all fluid was lost and all power steering! Replaced the pump with a refurbished unit but still no power steering. Used dextron fluid to refill and dont seem to have any leaks. Steering is not intermittent as iv heard on a few other post, there is no power steering at all. Before the pump exploded all was well with no issues at all. I expected if any hoses had been damaged to be losing fluid but there is no sign of any loss.
Completly lost as where to now!
Anybody with any ideas/experienceed the same issue?
Car is 91 Jspec TT Auto
mrmoose
Car: 91 300zxtt
maybe a bad steering rack, if the shaft wore through the metal ps body there was probably a lot of debris going into the rack.
Dazmcp
Thanks for that, it does seem that the rack is the most likely culprit, can a failed pump cause that much damage too it? I have had pumps go on previous cars and never had any other issues, they werent zeds tho! Also, there isnt any sort of special procedures with the changing of the fluid? Just wanna b sure i havent made any sort of school bo
y error and got an airlock somewhere?!
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
I don't think there's any way to really bleed the PS system. Assuming you have metal/debris in the fluid in the rack like mrmoose said, you could first try draining the fluid out of the rack and reservoir, then refilling with Dexron ATF and see if anything changes, If not, get a new rack
Dazmcp
Ye wen the initial pump went it emptied the majority of the fluid for me then its since been refilled and holding its fluid, the fluid i used to refill was the dexron stuff the dealership gave me, and with their help today the boys there all feel its pointing to the rack, the only other thing iv heard about elsewhere was sensors and hard steering failure modes :-S not a clue bout any of tht tho! And being between jobs, this may be open for a while!!!
t.mcginley.jr
1966 Ford Mustang
You could try running the codes at the ecu, but I think it's a mechanical issue (the rack) not an electrical/sensor issue.
Dazmcp
ye im looking into the racks just now, struggling to find remanufactured or new parts for RHD and not goin anywhere near dealerships for parts
t.mcginley.jr
1966 Ford Mustang
Z1 sells them supposedly... I searched "steering" on their site and went to the PS rack. There's an option to select "Right Hand Drive", plus you have to send in your rack as a core.
J30tChumpCar
Car: 1995 J30t Totaled @ Charlotte motor speedway
1994 J30 gutted caged road racer Now with VH45DE!
1966 Chevy Corvair V8 mid-ship conversion
I had issues with the screen filter causing a false full perception, fish it out, fill, work the wheel back and fourth, rinse lather repeat.
