Z32 Poly Rear trans mount?
chinaonnitrous
Car: 2002 Maxima to 2004 Evoloution to 1992 Integra
Has anyone done it yet? I know Mr. Wes was asking about it in the 300zx forums, but no one replied, and I havent hearda bout his progress.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
It should work...
Im going to consider getting one pretty soon.....
Rex
Car: None
The increased vibration transfer doesn't concern you?
What benefit are you looking to get from this piece?
elwesso
2007 BMW M Coupe
It limits engine movement.. Really i dont think it will transfer more vibrations. it wll be better than the likely crushed transmission mount thats in there now...
Rex
Car: None
Okay, I completely understand replacing an old/worn mount will net improvements, but given your history of vibration issues, I'm surprised to think you'd want anything "firmer" in there.
Wasn't the motor replaced in your current Q by a previous owner at T3? I can't imagine them swapping the motor and not replacing all the mounts?
elwesso
2007 BMW M Coupe
I wasnt refering to my mount, i was referring to the one in jesda's Q... My Q's transmission mount was changed out about 45k ago (at like 80k and i have nearly 125k now)... Its probably about time to think about another replacement... Another member on this forum is giving me a spare transmission mount for me to try, that is supposed to be "as new"...
Its more important that everything is in line (driveshaft, engine, transmission) and it stays in line. when thats the case, there wont be any vibrations... ... Plus with my high stall converter,i think i have more engine movement than regular Q owners...
chinaonnitrous
Hmm, not really looking for an extreme performance difference from a transmission mount. But just looking for little upgrades here and there. Im already upgrading most supsension bushings with poly/ball bearing arms, subframe spacers etc........ I know that the ride will ultimately be a little more harsh.
Now as for the amount of vibration that i'll get from this mount...not sure. but I'll give it a try.
Rex
Car: None
Cool, I was just asking, as it seems "we" fall into the trap of getting the (insert newest/best material) mount/bushing, when we don't necessarily need it's "benefit".
elwesso
2007 BMW M Coupe
China, when are you going to install it?????? LMK when you do.
chinaonnitrous
Fine fine....i'll call SPL today.........anyone in particular I should ask for? I know some of us have purchased from them....
Theres vibration at 1500~3000rpm.....Must change motor mounts too... I was following tanglora's posts, Im not sure if this transmission mount will show me improvment/worsening of vibration. I'll post results anyway, the vibration should get a tad bit better with a fresh block of rubber.
elwesso wrote:China, when are you going to install it?????? LMK when you do.
elwesso
2007 BMW M Coupe
I dont think it matters who you talk to, just be sure to mention NICO..
IMO, the closer you get to the rear of the car, the more effect vibrations have... heres my hierarchial order from most likely to cause vibrations to least...... (doesnt include the actual driveshaft being imbalanced due to the insulation coming out, all bets off)
1. Rear U joint2. Middle U joint3. center bearing4. Front Ujoint/flex disc5. transmission mount6. engine mounts..
However, i always recommend doing things starting with the easy and then going to the hard..... So that means, its best to replace the transmission mount first (easy and cheap parts) then you replace the driveshaft, and then you replace the motor mounts
Hope that made sense because im not really sure it did..
chinaonnitrous
Makes sense.........for me i just think, wear and tear needs to be replaced so eventually i'll be done.
chinaonnitrous
Screw it, I just ordered a NISMO one for a z32 40 bucks shipped. Anohter thing that bohtered me about the SPL one is that it said it removed the exhaust hanger bolts or what not..... Arent I supposed to replace thoes hangers too........*shrug* I guess Wes will do the honors of being the guiena pig.
elwesso wrote:I dont think it matters who you talk to, just be sure to mention NICO..
elwesso
2007 BMW M Coupe
screw that, nismo is cheaper!!!!!!
goody90q45
Car: 1992 Infiniti Q45 (sold)
The exhaust hangers bolt to a plate which bolts to the aft end of the transmission mount. There are about 8-10 nuts that have to be loosened or removed to get the assembly out. If you didn't pre-order through Joe you can get them at a dealership for about $25 apiece. You will notice a BIG difference in vibration. Once you look at your compressed transmission mount you'll have a good idea of what your engine mounts probably look like. Engine mounts are on my list of wannado's.
chinaonnitrous
Ordered my exhaust hangers today, with tie rod/steering boots, and a powersteering hose. =)
goody94q45 wrote:The exhaust hangers bolt to a plate which bolts to the aft end of the transmission mount. There are about 8-10 nuts that have to be loosened or removed to get the assembly out. If you didn't pre-order through Joe you can get them at a dealership for about $25 apiece. You will notice a BIG difference in vibration. Once you look at your compressed transmission mount you'll have a good idea of what your engine mounts probably look like. Engine mounts are on my list of wannado's.
chinaonnitrous
elwesso wrote:screw that, nismo is cheaper!!!!!!
If it works out I may be able to sell them new for about 60 bucks shipped.
elwesso
2007 BMW M Coupe
I dont have exhaust mounts.......
