WhatsADSM »
https://forums.nicoclub.com/whatsadsm-u29596.html
Fri Feb 12, 2010 12:25 pm
First off I don't think you know what you are getting yourself into with the 3.6 FD. RBs like to REV this is not your KA24 anymore. They want and like to rev. Around a 4:1 FD is best for the vast majority of RBers out there.
As for swapping the Q45 guts into a different housing and getting it to work with your 4-lugs. Basic premise is no it won't work. The Q45 differential has a different spline configuration which drives the use of the Q45/TT axles (which ideally you want anyways since they are beefier), and the axles drive the use of the differently splined 5-lug hubs.
You *may* be able to swap the Q45 ring and pinion onto your existing differential (I mean the diff itself not assembly). However even that I am not sure will work, considering the various different types of diff bolts that were used by Nissan in different R200 assemblies.
To make your life simple just get a more "standard" 3.9 or 4.08 differential and be done with. It might require changing some simple stuff like axles or output shafts in the worst case, but it is way easier and you will be able to keep your 4-lugs.
