I have no spark and the ecu isn’t throwing any codes. I’ve replaced the PTU and done the subharness delete. I tested the CAS and replaced the harness for it The CAS makes the injectors click so that’s all good. The fuel pump doesn’t prime but has pressure when Cranking. I’ve checked my grounds and coil packs. The coil packs are all good but i have no voltage on the coil pack wiring harnesses. I’m really confused why I have no spark and any advice would be greatly appreciated
