hooked up a battery, CAS, and tried to start car..
all it does is "Wha whaa, wha whaa, wha whaa" security lights comes on with every "whaa" spun CAS, all injectors fire, couldn't hear fuel pump tho..injectors were really loud...
every 4-5 spins on the CAS a loud WHOOSH/POP would come from the driver side intake..crank was not moving tho..no clue what causes that...
Edit: when cranking the car the sound isn't there, there is a hum from the front of the car with key 'ON' i smell fuel so I'm guessing its the fuel pump going...sounds like it catches, but seems like the security system kills it...i need to check the relays next..
