Z32 NA vs TT manual gearbox differences?
Discuss topics related to the VG and VE series engines.
Ezekial
Car: 2001 Nissan 200SX S15
Hi i was wondering if anyone can tell me if the NA Z32 300zx's and the TT version's use the same gearbox? or are there strength differences, casing differences, bell housing bolt pattern differences, spline, etc
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
Same gear box, same gearing, same strength, just about the same everything. The only difference is where the starter bolts to the bell housing and some material around the inner of the bell housing.
The TT uses a larger clutch and flywheel setup so there is slightly more material on the starter surface and a bit more clearance inside the bell housing.
Basically, the N/A transmission can be modified to work with the TT setup and would be just as strong.
Return to “VG30 / VE30 Forum”
