DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Sat Jan 19, 2013 8:38 pm
Not so sure it would go backwards or forward if it was hydrolocked, the fluid locks any piston movement as I found when I got into a surprise deep puddle awhile back...anyway, take the spark plugs out and put down some old bath towels over the plug holes, then remove your ignition fuse before cranking the engine by hand, then if it rotates, slowly a rotate it a quick click or two by starter to push any fluid out the spark plug holes. Your engine will rotate only at starter speed with the plugs out so don't worry about too much rotation speed, just be sure it moves by hand first before using the starter.
