rishar1 »
https://forums.nicoclub.com/rishar1-u215619.html
Wed Feb 06, 2013 9:18 pm
My 1990 z32 n/a has suddenly started cutting out. I was adjusting the tps, idle, and ignition timing and now when I drive it i wants to cut either the fuel or fuel injectors. If you hold it at about 2000 rpm it will rev then die then rev then die so and so forth. If I let it idle for a min or two then if i hit the gas it will rev all the way up then cut out again. It doesn't really completely die rpms just drop to about 500-600. When I checked it with conzult the injector pulse rate would drop from about 5ms to .2ms when ever it started to cut out. The exhaust also started smelling like a skunk spray even though I don't have any cats on the car. Just wondering if I should start digging through electrical or check for a bad fuel pump.
Also of note this car has a bad knock sensor and has had for sometime so it is in safety mode.
