Z32 master cylinder install tip (huge time saver)
matt4pl
Car: cars, anything fast, graphic design, lots of stuff
ok so i got a remanufactured MC from a z32 for my 240. i got the 5 sided plug removed by a shop cause i couldnt do it. there is no flared brake line fitting inside and the install on importnut.net says to cut up your old MC and take the fitting out and press it into the new MC. thats a lotta work and its hit or miss on wether it will fit right or not. i went hunting in a bunch of store and came across an adapter that will mate to the bubble flare fitting inside the MC and the hat style flare on the standard brake line. it's Eldelmann part # 271300
http://www.importnut.net/300zxbrakeswap.htm#MC was my referance for this
Hijacker
Car: '92 240sx Convertible
'94 F-150
what store did you end up finding that in? An advance auto or a local shop?
matt4pl
it was at lee auto parts but there is a catch... u gotta get a matching line fitting. u might have better luck with a different brand of fittings
