marty1mc »
https://forums.nicoclub.com/marty1mc-u151866.html
Sun Nov 07, 2010 1:57 am
Hi, there is a slight difference between the NA and TT transmission for the Z32. The TT transmission housing is larger by a few mm. This is to accommodate the larger TT flywheel. When people use the NA transmission in a TT, they have to grind the inside of the housing to make clearance and add a shim to the starter to move it out. Just be aware of this as the TT also has a different clutch, pressure plate and flywheel. The starter is the same on both.
The 98+ transmission was redesigned and is supposed to be superior. The only issue I have read about (I don't have one) has to do with the shifter breaking. It seems to be a new installation issue and not a reliability. But, I saw two posts from different owners that the shifter mount would come loose. But, it wasn't a huge deal.
As far as going for one, it's all personal preference. I had an NA trans with 156k on it and it was becoming toast quickly. I had 4th gear grind from the time I bought it and by the time I did the swap, it was grinding anytime I shifted into 4th or 2nd. Redline MT90 helped when I bought it, but not at the end. The transmission I got with my swap (USDM not JDM) had 68k on it and doesn't grind at all. So, I think its a crap shoot. If you can find a transmission with low miles, then go for it. I would be suspicious with anything over 120k.
