HoosierSX wrote:
i dont see how providing a less restrictive maf doesnt gain you anything
You're running a forced induction setup. The amount of free flow provided by a slightly larger MAF is peanuts when you have a device that is actively sucking in more air to compress.
The only point to upgrade to a Z32 MAF is when you top out your fuel injection setup, which on stock SRs, tends to be at around 250-ish WHP. The Z MAF is there to support larger HP numbers by providing accurate data to the ECU on air flowing into the system. It is not a power gainer itself. Much like how swapping to larger injectors doesn't miraculously give you more power, but more fuel supports increased air volume from a larger turbo to make the power.
