boileralum00 »
https://forums.nicoclub.com/boileralum00-u146.html
Sun Oct 27, 2002 9:18 pm
You might check out twinturbo.net for more info. I am trying to get my dual intake/ MAF setup working myself, and am wondering why you are only using 3 wires? The wires necessary to get my second MAF working and integrated into my AFC are (don't know the pinouts ROH): +12V power, Ground (to complete power circuit), signal +, and signal ground. Also, you should be using shielded cable to connect the signal+ and signal ground wires to the ECU. The shielding needs to be grounded to a seperate chassis ground at only one spot (i.e., grounding the shield more than once creates a ground loop, which if you've ever heard a car stereo w/ a similar problem, can distort the signal dramatically). HTH, again I would search on tt.net for more indepth info.
Rich
