Z32 MAFS hookup
CA18 RS13
Car: non-fwd japanese sports cars
could tell me exactly which wires on the Z32 MAFS hook up to which wires on the CA harness? also what is supposed to be done with the extra wire? thanks.
chezina
Click HERE! for Z32 MAF wiring into S13. The pins u don't need are unused so no extra wires. Hope this helps
CA18 RS13
this is what i found on freshalloy about the SR setup
compaired with the one you gave
*edit* sorry i posted this on the wrong forum but ill make it relivant. does the CA18 not need to add an extra ground like the SR's do?
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
That's the map I used to re-wire mine.
The 12V+ wire on the CA is black with a white stripethe (-) is all blackand the signal wire is like orange if I remember correctly (or was it green.... hehe cant' remember). I'll look at it when I get home and tell you.
The CA has 2 grounds, the same as the Z32 (plus the Z32 has an extra 'not used' wire. Just connect the grounds together and you're set.
hope that helps a little,
PaulOrlando, FL
boost junky
Car: 1984 200sx 1998 Neon R/T 1982 Malibu
Do you have to have the computer reprogramed for it?
CA18 RS13
Quote »Do you have to have the computer reprogramed for it?
[/quote]no i have an S-AFC
Chezedik
Car: 1991 Nissan 240sx
boost junky wrote:Do you have to have the computer reprogramed for it?
I have a KA that I am looking to keep NA, and I have heard that the MAF is a good upgrade. Can I run it without a RePROM for now, or do they have to be done together, if I am not interested in getting the unit you all refer to. PLEASE HELP!
