Naro182 »
https://forums.nicoclub.com/naro182-u5834.html
Sun Oct 03, 2004 10:30 am
well recirculated bov and blow through maf are two different things.
When talking about a bov theres two options, recirculated and open atmospshere. Recirculated means when the bov vents(too much psi) the air goes back to the intake piping. On a open atmosphere, the air just vents into the engine compartment sorta self-explanatory.
Now with a maf, there is also two options, blow through and pull through. The difference is where you place the maf. On a pull through the maf is after the intake and before the turbo. This is how most cars are setu, including how the 240sx comes from factory. The other way is blow through, people place the maf before the throttle body. There is advantages to both, its just depends on your car and how it runs.
The reason people talk about open atmos bov and mafs is tying together the tuning of the system...
Hopefully that helped a little bit, maybe someone else can clarify it a little better...
