SleepingTalon wrote:I've got a rb25det w/ safc, 550's, 2540, and just bought a z32 afm. What input/output settings are you using on the SAFC? Is in-2, out-4 correct with the z32 afm? The car is making 385whp at 16psi on pump gas, and the maf is now maxxed out. At any rate, I've had no problem getting the safc to control these injectors, and have used the safc in 750whp applications, so it'll work no problem with your setup.
while the safc _can_ control big injectors and diffrent mafs, it seems that the general consensus is that it still is fooling the stock ecu.from what research ive done on various forums and what not it seems that (to me) the best route is either a standalone like a pfc or aem, or to use the safc in conjunction with an ecu chip.i had an emanage on my car and while it did work i didnt like how adding or subtracting 'fuel' would mess with my timing maps, yes the emanage can correct for this but it was more hassle that i didnt want to go through with.i also noticed that on my friends car (440cc injectors, z32 maf, safc) that after the dyno tune that it idled weird, presumably due to the safc correcting for maf and what not.
i suppose all in all its not that bad of a device and it really is up to personal prefrence but for all intensive purposes i dont care for them and wouldnt use one on my car.
imho if you are looking for a moderate power rb20 or rb25 then a tweaked ecu and safc is just fine, but for one thats agressively modded a safc wont cut it.just my .02c on the matter.
