Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed Aug 06, 2008 5:57 am
The O2 sensor wire is an on/off circuit. The o2 circuit completes based on what the sensor detects. The wire should go hot if you manually ground the sensor circuit. you may have a continuity issue if you're getting no voltage to that circuit when you ground it out.
Looking at your pic, the cut white wire should be the MAF signal wire. Looking at my pinout, the only white wire near the securing bolt is in pin 16, which is two pins from the bolt. Pin 15 must be hidden in your pic, because it should be a green wire that goes to the consult port.
The cut green/black is a consult wire
The other cut wire goes to the JDM fuel pump control module (my circuit diagram makes it seem like the JDM pumps were multi speed)
Find the MAF signal wire and where it was cut and fix the circuit. Then I bet your car will run.
