z32 maf wiring into kae
wild_maxx
Car: 90 TT pearl yellow z32
how do i wire it in? there are 4 wires on the back to the z32 harness, 2 grounds, 1 maf signal, and 1 12 volt wire. Is the large thick white wire (being "E" on the maf) the 12 volt on the z32 plug? and the thick white wire on the stock plug the 12 as well?heres the diagram i am using.
lrb_2000
Car: '91 Nissan KA-T hatch
ka maf1. white - ECU MAF Signal 2. Black - Ground 3. Black with white stripe - 12v
signal wires will be same size... so match it up with the smaller white wire of the z32 maf. and the larger white wire is 12v.
Modified by lrb_2000 at 3:15 AM 8/29/2005
Modified by lrb_2000 at 3:16 AM 8/29/2005
