cheapscheisst »
https://forums.nicoclub.com/cheapscheisst-u51432.html
Tue Jul 22, 2008 1:09 pm
alright i'm about to install a z32 maf, 550cc injectors, and a boss tuned ecu in my s13 blacktop. obviously i'm going to do this in steps to make sure each component functions as it's supposed to. this would encompass (running car after each step):
1. installing z32 maf and setting sacf2 settings to 2-in 6-out.2. installing 550cc injectors and adjusting safc2 to -33% fuel correction.3. installing tuned ecu and adjusting safc2 to 0% fuel correction and modifying in/out settings.
here's my question. what in/out settings am i supposed to use with the tuned ecu installed? i assume that i wouldn't want to mess with the maf voltage since the ecu is tuned for a z32 input. therefore i would use a 2-in 2-out setting. is this correct?
Modified by cheapscheisst at 11:26 AM 7/23/2008
