z32 maf ?
themeanest240
Car: 1991 240sx
my question, is a z32 maf a waste of my time?i have a s13 redtop w/ FMIC, 3in exhaust, greddy rs bovi do have it ready to install, with safc2. i just wanna know if anythings going to change?sorry for such stupid questionthanks!!
Neil
Car: shooting laser guns
All a MAF does is measure the amount of air entering the engine. The shape and inner diameter of the MAF has no effect on the engine's performance.
Z32 MAF's are used to facilitate the installation of larger turbochargers because they have the capacity to measure a very large amount of air flow, where an SR maf has a relatively low "celing" to the amount it can measure.
Since you aren't running a larger turbo or even a boost controller, then unfortunately yes a Z32 maf is a waste of your time.
Also using an AFC is not the appropriate way to set up a Z32 maf. For half the cost of the AFC you can get your ecu calibrated to work with the Z32.
nzmoman
Car: 240sx 2 of em' and always lookin for more
its only worth it if you are going to be planning on making your car a +300whp car, and then if you can go D-jetro and afford a good tune i would opt to do without the MAF altogether.
themeanest240
Car: 1991 240sx
well im going to use the z32 because im upgrading turbo soon. it wont be driven much at all untill then, i will have ecu tuned after i decide injector size and turbo i want in long run.thanks.. i guess
nzmoman
if you use the z32 you will need to get a calibration...yo might as well wait for the injectors and get it done at the same time
