sr20det »
https://forums.nicoclub.com/sr20det-u2515.html
Fri Feb 06, 2004 10:10 am
ok guys hard to believe but my Atmosphere BOV works great. if you are havent this problem on Ideling when rpm drops from high rpm to low rpm first thing that i did to MY SAFC 1) i look at the voltage for the Z32 Maf Sensor than I edited so that the Throuttle is the same as the Throttle voltage, The IN1 as the same as the NE1, and the IN2 is the same as the NE2. try this. i try this and my ideling from high rpm to low rpm fix. IT IDELS!!!
