ericherm1 »
https://forums.nicoclub.com/ericherm1-u21447.html
Sat Feb 19, 2005 10:52 am
Hey guys I need some help diagnosing my problem.
I just installed a Z32 MAF on my 91 S13 Blacktop. It when on very easy. The wires do not need to be cut regaurdless what the people that sell these MAFs say. All you have to do is get a 1mm allen wrench and us it to pop the pin out of the maf harness and pop them in the z32 harness. Anyhow here is what I did:(this is looking at the Z32 MAF)First try: A -------- Not Used B -------- Black/White 12v power C -------- Black wire ground \____connected them together D -------- Black wire ground / E -------- White ecu signal WRONG SETUP F -------- Not Used
With this setup the car stated and ran but idled very very lumpy between 500 - 1100 rpm.
Second try: A -------- Not Used ----\ B -------- White ecu signal -----\ C -------- Ground to chassis ------\ D -------- Black wire ground -----WRONG SETUP E -------- Black/White 12v power ------/ F -------- Not Used ------/
With this setup the car started but then quit and would not run at all.I pulled voltage from the B and E wires while the car was in the on possition due to the fact that it wont run. Here are the voltages: B ----- 0.44v E ----- 11.85v
I believe that teh second try is the correct wiring but I cannot confirm this cause my car is not running .....
Anyhow, I did replace my O2 sensor and my plugs and my ECU is a Blitz Access tune that is supposed to be tuned for Z32 MAF, 550cc injectors, intake exahust, and upgraded turbo T28 or GT2530.
What am I doing wrong here?Is my MAF bad?
I can't install my stock sr maf cause I tore the housing apart for the stock mounting peice (works great by the way) here are some pics:
Modified by ericherm1 at 6:41 PM 3/12/2005
