dont be a jew? you are an *******. im not jewish but id be pretty offended if i was you tool. secondly you did NOT search. try searching the RB forum, under archives and in post bodies i found more than enough threads to keep me occupied for several hours.mmatl16 wrote:ok dumbfuc* do the search again and its two pages of mafs for sale or z32 mafs and sr crap.
dont be a jew next time and try helping instead of being negative
o please. are u serious.like uve never said "dont be gay" or "ur a fag"it was in the same context.Kamin wrote:dont be a jew? you are an *******. im not jewish but id be pretty offended if i was you tool. secondly you did NOT search. try searching the RB forum, under archives and in post bodies i found more than enough threads to keep me occupied for several hours.
wow how can i be more like u....u are so cool.....why dont u take ur own advice and leave. there is no reason for negativity here. this place is about helping people.Nameless EJ6 wrote:This is also not the only forum on the internet. If you search the skyline australian forums you'll find ALOT more info.
I suggest you keep searching, or kindly click on the 'Log Out' and never return. Biatch.
from the look of the filament in the RB maf, it should be hackable.Wulfgang wrote:So.... has anyone ever been brave enough to try to hack the RB MAF? It is identical to the Z32 MAF except for the electronics, which are probably nothing more than a wheatstone bridge, a constant current source, and a buffer. There could even be a trim resistor in there somewhere that could be tweaked.
mmatl16 wrote:there is no reason for negativity here.
You've proven my point. You're an idiot. Although you are far more sophisticated than the average idiot... you did search, just not thoroughly.mmatl16 wrote:ok dumbfuc*
That was the most lame attempt of an ego attack I've ever seen.mmatl16 wrote:u must be one of those people who hangs out with a group but is not really welcome, so u try to be tough on the internet....o well i guess if thats what gets you from one day to the next....keep trying to be tough
Not sure about the 25, but the 26 is at it's limits on the stock MAF at 400-450 hp. Also changing the MAF you will need some sort of ECU hack, PiggyBack, or Standalone for the car to run correctly. Or if you have a standalone that runs MAP, you can do away with all of it completely and change ITBs to a single Q45 TB. I'm working on that route myself.mmatl16 wrote:i searched around and couldnt find anything
i had heard a rumor that the z32 maf gives us rb guys power. does it give us as much as z32 mafs in sr's? and if they do give rb motors more power is at an n/a maf or tt maf
