Z32 MAF ground wires
b0rdin4life
Car: 95 240sx
I have looked around on the forum about wiring a Z32 MAF and I am a little uncertain as to what to do with the 2 ground wires... I was wondering if it is ok to run both ground wires (pin C and pin D) together to the black ground wire on the SR harness?
Hijacker
Car: '92 240sx Convertible
'94 F-150
Should be ok.
S13FASTBACKSR
Car: '92 Fastback SR powered
you can do that or ground one of the grounds to the sr harness ground and the other to the chassis...ive heard people say that one of those ways worked for them while the other didnt and other people say the other one did work and the other did not..however i dont know if that is true i think they should both work just fine.
