AX75F92 »
https://forums.nicoclub.com/ax75f92-u12477.html
Sat Mar 20, 2004 7:51 am
DriftS14,
That approximation will not work for an L-Jetro (air flow meter type) setup. The reason is because the Z32 AFM is a hot wire meter. The voltage map (which voltage values the meter associates with a given volume of air flow) is not linier on a hot wire. A hot wire map will show voltage as the Y axis and air flow as the X. Rather than simply drawing a straight diagonal line from the lower left corner to the upper right corner of the map (which would represent a linier characteristic), the hot wire meters voltage characteristic resembles an upward curve. Therefore any calculations you may derive from simply dividing your air flow percentages will come out drastically incorrect. Follow me?
Interesting idea though. I guess it should probably work on a D-Jetro setup. MAP sensors have linier voltage maps.
