Z32 MAF, 550 injectors and Power FC
Reffer
Hi.
I have fitted 550 cc injectors, Z32 MAF and a GT28BB 400hp unit.I have set the AIR FLOW to VG30.The injectors are set to 370/550 = 67 %
Yesterday I was on a track testing it for the first time.
When I was running at 1,0 bar boost the load was at 18.... Since it only has 20 "levels" I guess that this will give me a problem if I try 1,3 bar.
Can anyone give me a hint on how this this can be solved?
[email protected]
Phax
Car: Control dynamics
BUMP!!!
Lets get this guy an answer.
:help
SJN
Hi Reffer!
Nice to see that everything is in place! I haven't got my power fc controller yet, so I cant help you with this.
// Stefan
Nathan
I'm going to be having to do stuff like this soon too :(
I H8 UR DSM
Get the power FC pro....MAFS suck, and if your going that route anyway, mind as well get the best unit, and ditch the sucky mafs
Reffer
Haven't anyone heard about this problem before? I thought that it was quite common to use the Z32 MAF :(
Nathan
ahhh, but what do you do if you dont have the power FC pro? Just going out and buying a whole new computer isnt always an option...
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
I never found out where to even get a FC Pro.
I H8 UR DSM
Reffer wrote:Haven't anyone heard about this problem before? I thought that it was quite common to use the Z32 MAF :(
Its definitly a lot more common to find people usng the z32 mafs as opposed to a MAP sensor...but MAP sensor does have its advantages. Most people dont have the money to go with a full standalone, and the Power FC didnt have that option till recently when they released the Power FC Pro...dont know too many people who have that if anyone : )
Nathan
Well, I think I'll get to find out if I have this issue soon...as far as I know the Power FC I'm getting from nomore_mr2 is not the pro...which is fine with me so we'll see how it goes! And yeah, from what I understand the MAP sensor is the preferred option if you can afford the full standalone setup :)
Reffer
I still haven't found a solution to this :sad
But I'm thinking that maybe a FCD could be a solution. But I'm not quite sure how it works. Does is lower the signal from the MAF with ex 0,5 V always, or does it only make changes to the signal from a certain value ex 4,0 V?Any comments?
Reffer
:help
