Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Sat Feb 26, 2005 8:01 am
the easiest way to understand why the cylinder pushes less pressure is this. The bore is larger, so you have less concentration. With the cencentration of the fluid lessened, the pressure is decreased. Kind of like when you put your thumb over the end of a garden hose.
If you look at the brakes. You have 6 more pistons up front that bneed to be compressed. Since hydrollic fluid doesn't comrpess, you're exerting the same amount of pressure to all the pistons. So when you keep the stock S13 MC on the Z brakes, you have more pressure on 6 more pistons.
So the Z MC flows less to reduce pressure to the pistons. If you place that MC on stock S13 brakes, they won't clamp down enough.
