slayer6o6 »
https://forums.nicoclub.com/slayer6o6-u31510.html
Wed Oct 18, 2006 2:06 pm
I have searched about all I can take and I have just two questions-
1) I recently installed the Z32 LSD in my '89 240sx with the J30 axles-but what kind of bolts do I use for mounting the front of the diff? I used the OEM 300zx bolts, but the diff's bushings came loose and the front of the diff slid past the bolts, as the 300zx bolts don't have washers and just grab the bushing. Should I have used the 300zx crossmember, or the 240sx bolts ( I did try these but they seemed too short, and had a lock washer and a regular washer that the 300zx hardware didn't have)? What exactly is supposed to be used for mounting the front of this thing?
2) The diff clanks when I shift in the low gears, eben when I try to shift easy. Just to verify, does this mean that the bushings are bad?
Any help is much appreciated.
