z32 interchangable with n60?
moso240
Car: Ferrari V12 Powered S13
In Short I have a z32 Tuned ECU can i put a N60 MAF or is the output voltage way different? if i put it on will the car atleast idle?
tramp_drift240
Car: 1992 240sx SE Coupe
try it i guess.
normally you need to have the ECU tuned for the specific MAF.
i have an n60. and will probably have to get a tune specifically for an n60.
moso240
well i cant find a wireing diagram anywhere... is it the same as z32?
tramp_drift240
no its not.
theyve got different wiring i believe, and the hotwire stuff is different. different voltages or whatever.
not the same.
moso240
guess i have to go to the junkyard...J30's are everywhere j30 maf is equal to a z32/n62 correct?
zenki_myles
Car: 1995 nissan 240sx / 1989 honda civic
i might be wrong but i think n60 is an rb25 s2 maf as well as maxima so search for wiring for a s2 rb25 maf.
Hijacker
Car: '92 240sx Convertible
'94 F-150
moso240 wrote:guess i have to go to the junkyard...J30's are everywhere j30 maf is equal to a z32/n62 correct?
I'm fairly certain J30s are the same as Z32s as far as the electronics go. The J30 has a bolt up flange instead of a slip flange as their main difference
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
zenki_myles wrote:i might be wrong but i think n60 is an rb25 s2 maf as well as maxima so search for wiring for a s2 rb25 maf.
Wrong E60MAF is for RB25N60 for VG30 Maximas
DJButton
Car: 2010 Nissan 240sx
N60 works on Maxima and RB20 just change the plug itself. Don't think it's the same as an RB25 MAF, either S2 or S1, but I could be wrong. As far as Z32 and N60 being interchangable definitely not. I thought N62 was only on the VG30DETT, but again could be wrong on that.
