Z32 Injectors
KAT S14
Are the Z32 N/A injectors 370cc? And also will the N/A MAF work just as well as the TT?
Structure240sx
the n/a maf will work.
not sure about the injectors
Drift Machine
Car: 1991 KA-T 240sx
I believe the 1996 TT 300zx 370cc injectors will work with the KA rail. Or it's the 95, one of those years works. But once again not absolutely certain.
300max
Car: 1995 240sx ka-t 1997 Maxima SE
z32 NA's are 270cc, TT's are 370cc and are drop in, the maf is the same for both.
jab11185
Car: 1992 Nissan 240sx
what boost are the z32 maf's good up to?
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
It's not a boost number...it a HP number, as the MAF can only meter a certain amount of air...which corresponds to HP.
That being said, it's about 500rwhp.
That's +30psi from a typical T04E compressor.
Maybe only 24psi from a T66...
Who knows, too many other facted determine at what PSI you'll make what HP.
What are your goals???
- Brian
:: orion ::
Oh yeah...and Z32 TT injectors ARE NOT all the same.
They are all 370cc, but not physically the same size. Some years drop into a KA/SR rail, other years don't fit. Figure that out before you buy...
huguetpj
Car: 93 KAT Coupe
You will need 94+(meaning not all 94), 95 or 96 Z32 TT injectors.
jab11185
i was looking for something in the vicinity of 300 hp...will the maf plug in? or is there some kind of harness for that?
huguetpj
Car: 93 KAT Coupe
jab11185 wrote:i was looking for something in the vicinity of 300 hp...will the maf plug in? or is there some kind of harness for that?
You'll need a 300zx maf plug to splice your current harness into and then connect to the 300zx MAF.
Or you could always solder the wires directly... PITA if you ask me. The plug is like $20-30 anyway new. Or you could source it from a junkyard.
