240life »
https://forums.nicoclub.com/240life-u76914.html
Sat Jan 23, 2010 12:35 am
i got nothing to do to day....maybe i will dig the snow off my car and take a looksie for ya.....give me a bit its 5am so im not going to wake the neighbors. When I was originally wiring mine, I thought I had a bad chip. I called Jeff at Heavy throttle and was told basically as long as the harness and ignitors are making a path, the ignitor will work. There is no real special way to wire it up. So if your harness wire colors were red/ blue/ black/ white, you would cut the SR harness ends off, select 4 positions on the z32 pig tail and solder those conections in th order they were removed. The other side just has to match the other end.... basically you can use any 4 of the 6 z32 wires 2 are not used.
Modified by 240life at 2:46 AM 1/23/2010
