My Z32 had a wonderfully working HVAC system. Then 1 week after running it, it died
The controls on the Side POD do not work at all, no Beeps, No Screen.
Which wouldnt be a problem since i last set it to 23 Degrees C. (nice for me)
Although the the other problem is that Nothing with it works. The "Auto Amp" (Computer thingy... yes i said thingy
Since this problem occured i replaced my Mk2 controls & Computer with mk3 (i think) Controls & Computer. Which were tested before removing from the donor car and was in working order. So it cant be the controls or the Computer(i hope lol).
I have read most of the Online Factory Service Manual and done some of the tests mentioned there (as its not good quality).
The tests i have done are only related to power source and ground points. Pins 33 & 35 for 12v+ and pins 45&55 (i think) for ground. All are good. (12v to body ground for 33&35 and 0hms resistance from ground to body ground for 45&55).
Im not a total numpty when it comes to electrics as i have rigged up 3 switches to manually control the 2 air mix doors and the vent/defrost doors without the computer plugged in. But without the Blower motor working (havent found the correct pins yet) its going to get really cold really soon and driving at 60mph+ to get warm air inside the car wont work in the snow.
Any help will be muchly appreciated. It could even just be page numbers in the Factory Service Manual so i can have a look incase i missed something.
So please HELP before i go nuts
