freakonaleash1187 »
https://forums.nicoclub.com/freakonaleash1187-u12997.html
Sun Feb 13, 2005 5:12 pm
there are basically three ways to have better braking, 1) more braking area (i.e. bigger caliper), 2) better pads, 3) have the caliper farther away from the hub of the wheel (gives the calipers better leverage). due to the bigger diameter of the skyline front brakes, the caliper is moved farther away from the hub, which makes better braking with even the same caliper. if you order the skyline brake rotors from splparts.com, they send the adapter brackets to relocate the caliper farther out. bottom line, yes, the skyline brakes would be better.
