z32 fuel pump in my car
DrIft Ready
Car: 1990 silvia built sr..
i does not work...i pluged it in and ran the lines right..just does not pumpit work just nothing comes out...any advice?
Ca_Silvia
DrIft Ready wrote:i does not work...i pluged it in and ran the lines right..just does not pumpit work just nothing comes out...any advice?
are you positive the pump is still good?
DrIft Ready
brand new
damesta
Happened to me once, make sure your positive and negative hookups on the pump aren't backwards. Mine would come on and sound like it was working but wouldn't pump any fuel.
float_6969
It's a DC pump, so if you wire it up backwards, it will spin backwards. That means it won't pump.
DrIft Ready
I TRYED IT BOTH WAY JUST TO SEE... IVE INSTALLED 30 OR SO OF THEN JUST NEVER A Z32TT ONE
tyrannix
Car: go big or go home
did you just match the colors on the plug end to the pump end? (i just finished soldering a z32 pump myself and just matched up all the colors, as they looked like they all go the same places on both pumps... bu/r stripe = motor neg wh/br stripe = motor pos)
CJ
Modified by tyrannix at 6:23 PM 4/7/2006
DrIft Ready
i heard that u can only use certen years of the pumpmine has the fuel presur reg on topi can here it pump but nothing comes out the outher side
